Failed to export site: java.lang.OutOfMemoryError: GC overhead limit exceeded
2178
09-06-2021 12:34 AM
Stefan_Jung
we are running into a very strange issue when exporting the Portal for ArcGIS Site. The Portal crashes and the Portal log has the following error message:
 Failed to export site. Das Portal-Repository konnte nicht exportiert werden. java.lang.OutOfMemoryError: GC overhead limit exceeded
("The Portal Repository cannot be exported")
The corresponding error message can also be found in the tomcat log of the Portal instance:
 SEVERE [https-jsse-nio2-7443-exec-42] com.sun.jersey.spi.container.ContainerResponse.mapMappableContainerException The exception contained within MappableContainerException could not be mapped to a response, re-throwing to the HTTP container
The Portal does contain a lot of elements and more than 100GB in the content directory that needs to be exported. Maybe the export is creating too many temporary files and the garbage collector needs all available resources?
 Does anyone has an idea how to solve this issue?
Best,
Stefan
JonathanQuinn
Esri Notable Contributor
Where is your content located? Is it on the file system, or is it in cloud storage? What version are you using?
Stefan_Jung
Hi @JonathanQuinn ,
the ArcGIS Enterprise Version 10.8.1 is a completely disconnected environment. The content is located on a file share.
Best,
Stefan
