Scene Service is missing root node error
1862
05-17-2023 01:11 AM
wizgis
Hi All,
I have a hosted scene layer on ArcGIS Portal.
When I try to add the scene layer in scene viewer I get the error of Scene Service is missing root node. I tried rebuilding the full cache by going into the Manage Cache option however, that failed.
Looking into the logs, I found couple of  errors like:
The Layer <Layername> in Map 'Scene' is invalid. The base table definition string  <string> is invalid.  Invalid Connection Property.
GetLayersToCache failed
DoCook failed.
Any suggestions would be helpful.
Tags (3)
JamesBurton1
I'm getting the same error on some scene layers of mine that were working in the past but now have this error.
