SAML sign-in error after upgrading from 10.9 to 11.1
529
12-21-2023 01:22 PM
Craig_Lunde
We are getting the following error in the logs when logging into portal. SAML sign-in error: Invalid_SAMLResponse: Unable to login using Idp. 'NAME_ID' not found in SAML response. When you click on sign in it redirects to the login screen then it works. It will also work when using a bookmark. The error only shows when typing in the direct link " https://xxxxxx.xx.xxx/portal/home". Has anyone seen this error before?
