Hey all -
Chiming in here with what worked for us. We're still on 10.8.1. I got our organization AD IT specialist involved for the Azure AD admin center stuff.
1) In Azure Active Directory admin center, we added a group claim to the Portal application and configured it to use "Groups assigned to the application" and the Source attribute of "sAMAccount Name". I think returning only the groups assigned to the application resolves the issue of a user being a member of too many groups (as not all their groups will be returned, only the ones associated with Portal in Azure AD). This gets done once per application (i.e., per Portal - if you have Dev, Test, and Prod you would set this up three times, but once it's set it's set for good).
2) Still in Azure AD admin center, we also associated the groups of interest with the application (the Portal of interest; ours is named Portal for ArcGIS TEST). As new Portal groups are set up to track AD groups, those AD groups will need to be added here, particularly if you have the claim set to only return 'Groups assigned to the application'.
3) In ArcGIS Portal, I configured a group per the normal instructions for linking SAML groups. In our case, the Enterprise group name was just the group name, no domain prefix. I think this is because the Source attribute set in Azure AD admin center is just the group name. There is a dropdown option for using a prefix but we didn't use that one.
4) As mentioned by WilliamShoop, the SAML decoder extension (https://chrome.google.com/webstore/detail/saml-message-decoder/mpabchoaimgbdbbjjieoaeiibojelbhm) was very useful for checking the group attribute format in the SAML response. Install it, log into Portal, then check the SAML response available in the extension.
Good luck,
Jena
