Portal for ArcGIS 10.7.1: How the performance of the Portal for ArcGIS can be improved?
2066
5
10-20-2020 12:16 PM
JamalNUMAN
Legendary Contributor
I couldn’t figure out if there are tools by which the performance of the Portal for ArcGIS can be improved.
Jamal Numan
ShaneMiles
Hi Jamal NUMAN‌,
When you refer to performnce , what exactly do you mean? If you mean GIS infrastructure and IT there is a couple of options depeding on what your looking for:
Performance of services and layers is not managed within Portal itself but in the ArcGIS servers. There are a number of considerations surrounding enterprise performance thse include but are not limited to:
Hope this helps.
Shane
JamalNUMAN
Thanks Shane
Has the “Rebuild the index for Portal” any thing to do with the performance?
Jamal Numan
ShaneMiles
Hi Jamal NUMAN‌,
No problem. The "Rebuild the index for Portal" is usually utilised post upgrade and is because there are items, groups or users missing and completes the upgrade process for Portal. Before this has been completed search functionality will not work until reindexing is complete. So in terms of performance it assists with post upgrade however I would refer to the information provided in my first comment as a starting point.
Shane
JamalNUMAN
Many thanks Shane
Best
Jamal
Jamal Numan
DanDeegan
Our portal items got out of sync and tech support told me that that command doesn't do anything as of 10.6.
