Portal Fails on Server Role? Can I ignore this?
1707
05-23-2023 10:09 AM
Labels (2)
CarrieQuast
Hello there - I don't know if this is an error that indicates a bigger problem, or that I am missing a piece.
We are doing a new install of ArcGIS Enterprise, 11.1 on a Server 2022.  Everything installed fine, my webadaptors are working, and I got the server federated.
The only piece that was missing was I got an "Unable to load the ArcGIS Server backing stores and/or the ArcGIS Server license Information.
I found that I could assign a server role through portal administrator, which I did with no problems.
When I go to the logs, this is the error (note: my domain name is removed in the screen shot below)
It looks like its not finding the raster store, which I'm fairly certain I didn't install.
I've done a repair on the portal, server, and datastore.  My federated server in portal comes back as "all systems operational", in Server Manager, my ArcGIS_Data_Store validates as well.
So, my question is, can I ignore this, or do you know of a way to fix it?
I'm still learning how all this works, so there may be something that I missed when I set this up.
JalesM
by Esri Contributor
I found the following article and it seems that the internal certificate is the issue:
You can probably ignore it, but it is best practice to use a CA signed certificate in your deployments.
Here is the documentation on how to import a CA signed cert into Portal and Server Admin endpoints:
Note that the server/domain certificate that you use for Portal and Server should be issued to the hosting machine's FQDN and not the DNS alias.
JalesM
by Esri Contributor
CarrieQuast
My issue was that I didn't fully import the certificate into server - I got it uploaded, but failed to configure it.  The last bullet point (Configuring https using an existing...) gave instructions on how to configure it. Once I got it configured, I restarted the server for good measure, and than tried again.
Thank you for your help!
JalesM
by Esri Contributor
Awesome!! Glad it worked out!
