Portal Error - The portal site is currently unavailable. Please contact your portal administrator to resolve the issue (Log files attached)
21015
13
08-22-2018 04:37 AM
SamJakson
Hello!
I've recently inherited a  portal configuration (version 10.6). The apps seemed to be running fine yesterday; however, now they are down and I am unable to access the portal homepage.
I've attached the .log files under <install dir>\framework\runtime\tomcat\logs folder - as far as i can gather the problem seems to be outlined here:
'Cannot connect to database: jdbc:postgresql://localhost:7654/gwdb Connection refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.'
Any help would be appreciated. I'm a long time ESRI user, first time portal admin!
GlendaRoman1
Hi. Could you share where the server.XML is found.
IslamSaeed1
HYG , kindly note that i am working on ArcGIS Enterprise 10.6.1.Hope it helps
you will find the server.XML under the following path
[installation directory]\framework\runtime\tomcat\conf
HillaryBjorstrom
I had esri support and we added the primary site admin security to ProgramFiles\Arcgis and arcgisportal folder then added same account for sharing those folders. restarted service and it worked.
FernandoMarin
are you trying to publish data from a geometric network? if you do, you have been affected by this  https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDE1MDYzMg== and you'll not be able to upload data coming from a geometric network to AGOL
