Portal 11.5 Upgrade problem
1086
12
12-09-2025 02:03 AM
LiveHus
Hello
I just upgraded my Portal from 11.1 to 11.5 manually - this was successful, until i tried accessing my Portal home page at https://my.portal.com/portal/home, I am then redirected to portal/home/error.html without any further errors. This also applies when I try locally with FQDN, so not a WebAdaptor issue in my eyes.
However, I am able to reach portal/sharing/rest and /portal/portaladmin without any errors. And yes I have tried:
  • restarts
  • clearing my browser cache several times
  • updating my browsers (Edge and Chrome) to the latest version
  • private window
Anybody else have encountered this issue before? Thankful for any tips
LiveHus
I have also checked my Portal Index, which is ok
RyanUthoff
MVP Regular Contributor
Have you checked the Portal logs to see if there might be any useful information in them?
LiveHus
Portal logs is not giving anything besides these:
Regardless, I think the Portal should be accessible despite the federeated ArcGIS Server not being upgraded yet
RyanUthoff
Yeah, I agree with you. Portal should still be accessible despite those errors. It looks like someone else reported the same issue. But unfortunately, there was no resolution posted. https://community.esri.com/t5/arcgis-enterprise-portal-questions/arcgis-enterprise-11-5-upgrade-erro...
DavidColey
MVP Frequent Contributor
There are likely issues with accessing the items in the portal postgres db..... There is some kind of missing or mis-configuration of some config files.  You really need to file a support ticket.
LiveHus
Thank you for your answer. Is it worth attempting to roll back the snapshot taken of the Portal server before upgrading and trying to re-install?
DavidColey
Without knowing anything about your deployment, all I could say is it would depend on how far along you are with the upgrade and whether or not this is a production deployment.  I think at this point you should work with support if possible.
Priya_Das
Hi @LiveHus
  1. It worth reverting back to snapshot and start upgrading it again.
If not,
  1. Ensure portalURL and privatePortalURL match your FQDN and protocol (HTTPS). (<Portal install directory>\arcgisportal\framework\etc\portal.properties)
  2. Could you try accessing Portal home: https://my.portal.com:7443/arcgis/home
  • If this works, the issue is with the reverse proxy or WA mapping.
  • If it fails the same way, the problem is inside Portal itself.
3.Check if your SSL Certificates matches.
LiveHus
I tried rolling back the snapshot and re-upgrading Portal. However, I was forced to run a post upgrade in arcgis/portaladmin in order to finish the upgrade. I also had to repopulate the licence file
This was despite finishing here:
I am still unfortunately experiencing the same error.
And yes, I am getting the error with https://my.portal.com:7443/arcgis/home, so it must be Portal itself.
