Wasn't sure whether to put this in the Portal community or the Python community.
Have a user account setup on a recent upgrade to portal 11.1. Scripts using the account have no problem accessing the portal if they use arcpy.SignInToPortal() but scripts fail if they attempt to login via arcgis.GIS(). The scripts work fine on portal 10.9. Checking if this is a bug or possibly an upgrade setting miss somewhere.
User is Creator type, publisher role. However, user ID used on 10.9 was Pro Advanced. Did have someone test it on 11.1 with another ID as pro advanced and still got the login failure.
from arcgis import GIS
import arcpy
portal_url = 'https://portal.ourportal.com/portal'
usr = 'username'
gis = GIS(portal_url,usr)
>>>Enter password:
# VERSUS
arcpy.SignInToPortal(portal_url, usr, pw)
TRACE DUMP...
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1948, in _check_product
res = self.get(
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 871, in get
return self._handle_response(
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1008, in _handle_response
self._handle_json_error(data["error"], errorcode)
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1031, in _handle_json_error
raise Exception(errormessage)
Exception: User not allowed for this account
(Error Code: 403)
During handling of the above exception, another exception occurred:
File "<stdin>", line 1, in <module>
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\__init__.py", line 585, in __init__
raise e
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\__init__.py", line 524, in __init__
self._portal = _portalpy.Portal(
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\_impl\_portalpy.py", line 205, in __init__
self.con = Connection(
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 354, in __init__
self._product = self._check_product()
File "d:\ESRI_conda\envs\arcgispro-py3-clone\lib\site-packages\arcgis\gis\_impl\_con\_connection.py", line 1954, in _check_product
res = self.get(baseurl + "info", params={"f": "json"})
(Error Code: 403)
VERSIONS:
portal 11.1
arcgis 2.1.0.2
arcpy 3.1
