Need help converting an Aerial photo (street) into a vector layer
4112
01-27-2011 03:55 AM
TarikEddial
Dear members of this forum,
In order to use a climatological model (SOLWEIG) for the prediction of mean temperature changes due to vegetation, I need to be able to convert a google earth screenshot of a street into a vector layer (Building edges) in ArcGIS. I'm not sure if there is a method available in ArcGIS to draw lines over the underlying aerial photo? Or maybe there is a tool that converts the outlines of the photograph into a vector layer?
I was hoping if anybody could point me in the right direction. Maybe there are some tutorials available for me to look at? Surprisingly, I did not find any exercise like this in the book Getting started with Arcgis.
Thank you in advance for your help,
Kind Regards.
Tarik
SimonKettle
Hi Tarik,
You mention that you want to "convert a google earth screenshot of a street into a vector layer (Building edges) in ArcGIS", are you using Arc10? If so it maybe easier [and avoid legality issues with Google] to use the aerial imagery offered via ArcGIS Online and Bing Maps you'll find it as a pull down on the 'add data' button. If you can then you can have the aerial imagery on the user interface rather than having to; grab, crop, inport, georeference exported JPEGs or TIFFs.
If not you can export a google map via export under the file menu (if you have Google Earth Pro [where you pay a liscene fee]) or you can take a screen shot and edit that image (using photoshop or any image editing software [I am not sure if that is technically legal]). You will have to have a look for whether Arc can inport a KMZ (Google Earth file) directly [as I'm not sure off the top of my head].
When you mention about methods available in ArcGIS to draw lines over the underlying aerial photo you can just create a feature class and using the editing tools 'trace' the map, which is easy enough [you do this by starting a edit session and using the tools there].
If you are looking to automate the process you need to bear in mind that the raster to polygon tool (as you said you want to draw dwelling polygons) only really works with TIFF files at around 600dpi that have black and white content only.
I hope this helps.
TimSpivey
Tarik -
if you are in the USA, you may be able to get US Department of Agriculture aerial imagery from 2007 or 2009 as a free MrSID download. It's the imagery Google uses for our state.
As for tracing building footprints - either manually creating polygon features one at a time, or buying image-analysis software such as ERDAS (now Leica) Imagine.
