Missing Domain Description in a Published Map Service
4901
6
11-01-2022 04:10 AM
majdi_turkman
When a service is published (using ArcGIS Pro 3.0) to the Portal (v11.0), domains set to fields are not acknowledged with the service, and I can only see the coded value but not the description. Service data is referenced from an Enterprise geodatabase (SQL Server).
Any ideas???
GeorginaScholes
Do you have the Transfer Field Domain Descriptions setting turned on in Geoprocessing Environements:
JackFanZhang
I had the same issue. ArcGIS Pro 2.9.5, ArcGIS Enterprise 10.9, SQL database. Tried the suggestion above didn't fix the issue (not sure if that's really a needed step anyway).
The trick here is that the Enable schema lock has to be turned on when publishing. Dont know if this has been documented by ESRI.
msummers
If you have a large number of coded value domains, you may have more than are included by default.
You can change the value when sharing a map image layer from Pro under the configuration tab > Advanced.
Expand the Advanced heading to set the following parameters:
  • Enter a value in the Max number of coded domains box to specify the maximum number of domain codes returned from fields, subtypes, layers, and tables. The default value is 25,000."
OfraAi
I have the same problem
I have an existing layer with two fields with domains (text-text). Today I've added some more fields with domains (code-text). It works fine in PRO. After publishing - the fields were added but not the domains.
Arc GIS Enterprise 11.1 and PRO 3.0.3
I've checked all the above but it's still not working. Any other idea?
Thanks
Ofra
OfraAi
Stopping and starting the arcgis server solved the problem......
Ofra
StefanUseldinger
I am also facing this issue with ArcGIS Pro 2.9-3.2 and Enterprise 11.1-11.3 on two different Enterprise sites (Base deployment+HA).
The best workaround is to restart ArcGIS Server.
Second best option is to change the service instance from shared to dedicated. However, if You revert it back to shared instances, You will again loose Your domain bindings...
