Loading an external list
1225
08-28-2025 11:12 AM
doronwen
I have a field I'd like to create a drop-down list for. The drop-down contain 300 options. I'm not going to enter 300 options manually.
Is there a way to upload a list in Portal? Similar to running the Table to Domain geoprocessing tool in ArcPro?
I'm using Portal 11.1. Soon I'll be using 11.3.
doronwen
I really wish ESRI would have this option of uploading a csv file under "Data" and "Field" window, but here is the solution/workaround:
  1. Open the hosted feature layer in ArcGIS Field Maps desktop version and create a form.
  2. Add the layer that needed a list.
  3. Select "Combo" under Input Type.
  4. Click "Manage List".
  5. At the bottom, click "select from your device" and upload a csv.
  6. Click Done and save your form.
The combo list is now saved in your hosted features.
Laura
by MVP Regular Contributor
I would create the domains in Pro and then publish.
doronwen
I tried that but it says the layer is "read only" for some reason.
doronwen
doronwen
Apparently, this is not an issue in ArcGIS Online or Enterprise 12.0 or later.
See this post: https://community.esri.com/t5/arcgis-enterprise-ideas/adding-an-option-to-upload-a-csv-file-to-creat...
