Is it possible to order item contents within a Portal group?
865
02-16-2022 03:41 PM
Yuriko
I am using Enterprise Portal groups to collate data layers for curated filters used by the 'Add Data' widget in a web app. Currently, there is no apparent order to the list of layer items. Is it possible to specify the default order in which the layers appear so that similar items can be grouped together in sequence?
I understand the widget interface allows the user to sort the items by 'title', 'date', etc, but I would like to set a default order. I believe we can categorize and prioritize content at the organizational level, but is this also possible at the group level?
Yuriko
I received confirmation from ESRI support that this functionality is not available.
Yuriko
