Expression Popup Formatting
3292
6
08-09-2022 04:43 PM
RyanTucker
Portal 10.8.1 Popup expressions that are pulling from related tables work fine and are formatted correctly in map viewer classic popups. But when I view the popups in WebAppBuilder the popups are all bunched together.
Any ideas?
JohannesLindner
Can you post the code please?
Have a great day!
Johannes
RyanTucker
@jcarlson @JohannesLindner
The Arcade code I'm using is below. Thank you for taking a look.
   Access 'Parcels has SiteAddressPoints' relationship using the function
   FeatureSetByRelationshipName. This will pull all Base addresses on the
   parcel from Site Address Points feature
// These are the fields that need to be accessed from the related table
var assrFields = ['SITEADDID', 'FULLADDR']
// This is the variable to pull the related table records
var relatedrecords = (FeatureSetByRelationshipName($feature, 'SiteAddressPoint', assrFields, false))
// Declare variables
var popupString = ''
var linebreak = "-------------------------"
   the popup expression is constructed by using a
   For Loop to iterate through all related features
for (var f in relatedrecords)
popupString += linebreak
    // If SITEADDID is not empty then add declared variable "a" to the popupString
    if (!IsEmpty(f.SITEADDID)){
        var a = (TextFormatting.NewLine + "APN: " + f.SITEADDID)
        popupString += a
    // If FULLADDR is not empty then add declared variable "a" to the popupString
    if (!IsEmpty(f.FULLADDR)){
        var a = (TextFormatting.NewLine + f.FULLADDR)
        popupString += a
popupString += TextFormatting.NewLine + linebreak
return popupString
jcarlson
How are you handling line breaks in your popup expression? It looks like that's probably the cause, somehow WAB is ignoring your line breaks.
- Josh Carlson
Kendall County GIS
JohannesLindner
Hmmm... I can't reproduce this, they look the same to me:
Map Viewer Classic:
Web App Builder:
But, notice that the first "linebreak" line in my popups is only half length (the last one, too)? If you look at your code, that makes sense: At the end of each iteration, you add a new line and linebreak, at the start you add linebreak. So for each iteration except the first, the dashed line on top will be 2 * linebreak.
Looking at your popups, I don't see that behavior, so unless I'm missing something, this doesn't seem to be the code your popups use.
Anyway, try a slightly different approach:
var popupLines = [linebreak]  // we're using an array to store the lines of the popup
for (var f in relatedrecords) {
    // If SITEADDID is not empty, push it into the array
        Push(popupLines, "APN: " + f.SITEADDID)
    // If FULLADDR is not empty, push it into the array
        Push(popupLines, f.FULLADDR)
    // get the dashed line in
    Push(popupLines, linebreak)
// Concatenate the array with NewLine and return
return Concatenate(popupLines, TextFormatting.NewLine)
Have a great day!
Johannes
RyanTucker
@JohannesLindner  Thanks for looking.
Im thinking the issue is deeper than Arcade for the following reasons:
1. This happens on Chrome, Edge, and IE11(Still have a machine with IE).
2 .  When I highlight the popup info in Map Viewer Classic and inspect it under Chrome the <span> tags      have  class="newcharline"   in the code
When I highlight the popup info in WebAppBuilder and inspect it under Chrome the <span> tags are missing the class="newcharline" code.
I have a ticket with tech support open on this as of this morning.
RyanTucker
I ended up having to upgrade my Portal setup to 10.9.1 to resolve the issue.
