Portal login failure after upgrade to 10.9.1. Unable to login using IDP.
1583
08-18-2022 07:16 AM
SOVANHALDER
We did upgrade Portal for ArcGIS from 10.8.1 to 10.9.1. After that we are not able to sign and getting the below error
Unable to login using IDP. IDP supports encrypted SAML Assertion, but send unecrypted Asserstion
As we do not use ArcGIS log in, we are currently locked out. Can anyone help how enable ArcGIS Login or solve this issue?
TIA
S
KaitlynStevens
Hello, have you seen the solution in this technical article? https://support.esri.com/en/technical-article/000027174
Let me know if you have any questions. Hope this helps.
Kaitlyn
KaitlynStevens
Kaitlyn
SOVANHALDER
Thanks Kaitlyn. It worked...
S
ZivCohen-Sollal
Same SAML error after upgrading from 10.8.1 to 10.9.1, after enable Built-in access turning off "Encrypt Assertion" in SAML setting solved the Problem
