Error message: cannot login to Portal
263
08-04-2025 12:34 PM
TSchrock1
ArcGIS Portal 11.4. I received this error late this morning and cannot log into our Enterprise Portal. Anyone else experiencing this error or know what is going on. I sent in a ticket to Esri.
Error message: Unable to login using Idp. Error validating SAML response java.security.SignatureException: Bad signature length: got 512 but was expecting 256
Thanks!
CodyPatterson
MVP Regular Contributor
Hey @TSchrock1
You may need to re-exchange the metadata in your AD environment with your Enterprise Portal. You may need the built-in administrator to access these settings and change them. I would have you or your IT generate a new metadata file and insert it here on Organization > Settings > Logins > Configure login
Cody
CodyPatterson
Hey @TSchrock1
Cody
