Error: Accessing data failed
2066
01-15-2025 01:49 PM
TommyJackson
When creating a feature layer in Portal, the features render correctly, and all fields appear in the attribute table; however, no data is displayed. Symbology can be applied based on the attribute values. The feature can be opened in ArcGIS Pro, but when you interact with the pop-up, only field names are shown without any corresponding values.
I’ve attached a screenshot with several snippets for reference. I found a similar issue documented for AGOL (https://support.esri.com/en-us/knowledge-base/accessing-data-failed-000016280), but my data is referenced, and there are no <Null> values as indicated in the article.
Any assistance would be greatly appreciated.
RyanUthoff
MVP Regular Contributor
Are you able to access your ArcGIS Server logs and see if there are any log messages regarding this issue? Also, it might be helpful to open your browser's dev tools, replicate the error, then see if there is any useful information in the internet traffic.
RyanUthoff
TommyJackson
Thank you Ryan! I didn't notice there were spaces in a field name containing the word "of" (which is also a reserved word in ESRI products) within a view that I joined to in SQL.
TommyJackson
I got this, headed out for the day now. Will revisit it tomorrow morning. Thanks for some direction Ryan!
