Disable the Scene Tab in Portal
3831
07-09-2015 09:04 AM
Drew
Is there a way to disable the Scene Tab in Portal?  (front end or back end)
Our basemap cache does not match the desired tile schema so it throws an error each time it loads.
We have one additional scale different (1:564) than the ESRI basemaps and I believe this is causing the issue.
Drew
JacobBoyle
In the config.js file, there's a variable called sceneViewerEnabled, change it to false and restart your portal.
This page will help you find the file in question: Setting advanced portal options—Portal for ArcGIS (10.3 and 10.3.1) | ArcGIS for Server
You should be good to go!
JacobBoyle
Drew
Thanks Jacob!
I think that will do it.
I found the variable  - I will restart the service at an appropriate time.
Drew
