Creating initial Portal administrator account using 10.3.1 AMI on Amazon Web Services (AWS)
5277
06-17-2015 07:40 PM
by Anonymous User
Not applicable
Hi. Has anyone else successfully got Portal going using the latest 10.3.1 server AMI on Amazon Web Services?
I have created a server using this AMI, which comes with Portal pre-installed. The documentation (link below) says to go to the following address to set up the initial administrator account:
https://<fully qualified machine name>:7443/arcgis/home
This address just comes up in the browser as 'This webpage not available, ERR_CONNECTION_REFUSED'.
I have tried using the ip address, computer name, AWS public name, and a public domain name that I have created (and that has the SSL cert bound to). None of these get to the portal page.
Going to https://localhost/portal or substituting the AWS public name or the public domain name for 'localhost' all redirect to the webadaptor configuration page which is https://localhost/portal/webadaptor  but of course I can't configure the web adaptor without first setting an initial administrator account.
I am following the documentation at http://server.arcgis.com/en/portal/latest/administer/windows/deploy-portal-on-aws.htm
Any ideas?
Cheers,
-Paul
by Anonymous User
Not applicable
Hi Daniel - thanks for your reply. Very sorry, I forgot to update the post as someone helped me troubleshoot from elsewhere.
The issue was that the Portal service had been started, but not set to 'Automatically start', so restarting the server had turned that service off again. Setting it to automatic has solved the issue.
(on to the next issue now... Federating Portal! but that's another discussion...)
Thanks again for your time.
-Paul
JayantaPoddar
Hi Paul,
The initial administrator configuration page should come up just after installation of Portal for ArcGIS.
What page are you getting when you enter https://localhost:7443/arcgis/home
What is your fully qualified machine name?
Think Location
by Anonymous User
Not applicable
Hi Jayanta
No page loads at all. The error that comes up in the browser is that the connection is refused/rejected.
This webpage is not available
I previously upgraded a 10.2 installation of server (which did not have Portal installed) to 10.3 and then installed Portal, and the link that worked was:
https://ec2-xx-xx-xx-xxx.ap-southeast-2.compute.amazonaws.com:7443/arcgis/home
which is the elastic IP of the server. But it does not work on this instance, which was based on an AMI provided by Esri which had Portal pre-installed. The server name is win-fur97r87gbu
DanielUrbach
Hi Paul!
If you go to your AWS Console and look at that AMI, does it have a public DNS name assigned to it? (It should look similiar to the one you mentioned above)
If not then you will need to set up an elastic IP for the server in the same way you did with your other server which worked for you.
Can you also confirm that the security group in AWS that your server is a part of has port 7443 available?
by Anonymous User
Not applicable
-Paul
