Collector for Windows 10 with Portal
2612
03-04-2016 05:18 AM
JoeHershman
MVP Alum
Collector for ArcGIS Windows 10 version does not seem to work with Portal
When I try to connect to Portal using the same Url I use on my Android device (https://portal.mydomain.com/arcgis).  It goes to some page within the /portaladmin API instead of connecting to our Portal (see image below)
To re-iterate, this works from an Android device so I know our Portal is setup correctly.  Also the Windows 10 Collector does work when I go to AGOL
-Joe
-Joe
JoeHershman
MVP Alum
This is the correct solution.  Thanks
-Joe
