Can't Upload File Geodatabase with Domain
594
12-20-2019 04:06 AM
JasonCyphers
Occasional Contributor III
Trying to upload a zipped file geodatabase to Portal (10.6).  The database has several domains, and I've drawn one feature in to the feature class.  When I try uploading the zip file to Portal, to create a hosted feature service, all I get is "there was an error" in the upper right corner of the screen, with no details as to what the error is.
I created a copy of the database, removed the domains, and it uploaded fine.
Any ideas?
RebekahPolette
New Contributor III
Just wanting to know if you established that the problem was the domains? I am also getting errors when uploading a fgdb that has domains but I can not figure out the problem.
Regards
Rebekah
