Broken link to jpeg: How to fix?
3109
10-06-2010 09:44 AM
847396730
Good morning! My layout window includes our state seal on the marginalia. The state seal is a jpeg.  The jpeg to which I would like to connect has been moved and renamed.  How can I relink the broken connection?  Thank you!
JanetMerkt
I usually delete the old one (where it appears to be from the path it throws in there), and then I just reattach it.
Bobby-JoClose
You probably already figured this out....
In ArcGIS 10, if you double click on the missing graphic you will get the picture properties dialog. You can navigate to the new jpg there.
