ArcGISPortal federated with ArcGIS Server using f5 instead ArcGIS webadpator
862
01-08-2022 12:36 PM
houdtrumboo
We have two ArcGIS server site (only one server at each site handling different load) and we have to federate them. now my questions
1. Can we federate both sites with on ArcGIS portal
2. Can we we F5 load balancer instead in ArcGIS web adaptor. from the different posts it seems with ArcGIS server it's okay but not With Portal
There is confusion in documentation at some places it says it can't be and some place it can be
ESRI folks please respond
https://enterprise.arcgis.com/en/server/latest/deploy/windows/using-a-reverse-proxy-server-with-arcg...
Tags (1)
Yes the load is observed
houdtrumboo
Please can you give more detail?
JonathanQuinn
Esri Notable Contributor
Yes, you can federate both, assuming they're not active/active siloed environments, but unique sites hosting different services. If they're active/active siloed environments, you'll need to set up a multi-machine site instead.
And yes, you don't need the Web Adaptors, you can use F5 instead of the Web Adaptors.
