ArcGIS Reverse Proxy Issue
1159
11-27-2023 06:47 AM
CodyPatterson
MVP Regular Contributor
Hey all,
Recently we employed a reverse proxy into our network to allow public access to our portal. When attempting to access a hosted feature layer from a computer on the network using the reverse proxy link, I'm getting this:
When I'm accessing the same item, using the same link, on the portal server, I'm able to see the item and access without issue, no Invalid redirect_uri.
So far, I've updated the App Info with all URL's that will be applicable including the reverse proxy url, what should I attempt now?
Thank you in advance!
CodyPatterson
Hey all, for some reason, I just needed to clear my cache, once I logged into the portal administration URL, it immediately started the redirect_uri issue again, then another clear of the cache and I was seemingly back in.
CodyPatterson
