ArcGIS Pro Published Services Incorrect URL
1777
11-01-2023 09:46 AM
CodyPatterson
MVP Regular Contributor
Good Afternoon,
I've just recently setup most of my companies Enterprise ArcGIS site and I've came upon testing the ArcGIS Pro SQL connections, and publishing of services. I was able to publish the information without issue, but when attempting to access the information published through the Map Viewer, it's inaccessible.
The URL at the bottom references an incorrect web adaptor, https://my-company/arcgis/ the correct URL would be https://my-company/webadaptor/. Changing the link allows me to access the information without issue.
I attempted to research this, but most of the time it's due to an incorrect services URL, but mine are correct, as shown:
Validation shows correct as well:
I was curious what I should check out from here forward?
Thank you in advance!
CodyPatterson
I ended up figuring this out, not entirely sure why, but only in one location did it have the incorrect service URL, that was in the ArcGIS Server Manager under Services > Sharing, changing the service url from arcgis to the webadaptor url, it worked without issue.
CodyPatterson
Should have attached the URL, this is what I am seeing:
CodyPatterson
