ARCGIS online basemap
945
02-09-2014 11:04 PM
HassanAbdelghafar
Hi All
I face this problem frequently would you please anybody assist me how to solved
when I open ArcGIS online to download online base map for world countries I always get this error
Invalid Package.
Error reading package content.
DXXX
Hi All
Invalid Package.
Strange, Contact your ESRI distributor.
NidhinKarthikeyan
Honored Contributor
Hi All
Invalid Package.
You can try the following workaround:
Change the file handler's unpacking location.
1.Navigate to C:\Program Files\Common Files\ArcGIS\bin.
2.Double-click ArcGISFileHandler.exe.
3.In Package Location Options, select the "Use user specified location" option and click the ellipsis (...) button on the right.
4.Navigate to the correct folder location for the file handler to unpack.
Make sure that this folder has read/write permissions.
LucasDanzinger
Esri Frequent Contributor
The above suggestions is a good one. You might check out this blog if that doesn't help.
