Arcgis Enterprise portal with Amazon S3 bucket configuration
1772
04-17-2022 07:22 AM
SreejithSreenivasan
Trying to configure portal content into s3 bucket. Configuration is successful ,if we provide "objectStore" values as s3 bucket name
Ex:
"type":"cloudStore","provider":"Amazon",
"connectionString":{"region":"me-south-1","credentialType":"IAMRole"},
"objectStore":"portal-contents-bucket" -- working
We would like to configure the portal content directory inside one of the folder in the S3 bucket . But If we provide "objectStore" values as folder name inside the bucket (portal-contents-bucket/portalcontents) it is failing. Error message is "Cannot write to the portal-contents-bucket\portalcontents\ S3 bucket."
Ex:
"objectStore":"portal-contents-bucket/portalcontents" -- not working
Can we provide "objectStore" value as the folder inside the S3 bucket or it should be always S3 bucket name?
JonathanQuinn
Esri Notable Contributor
There are no real "buckets" in S3, so I'm not surprised that's not working. When you see item "folders" under the root bucket, they're just key/value prefixes. What you're looking to do is not possible.
JonathanQuinn
SreejithSreenivasan
Thank you JonathanQuinn for the comments. For datastore backup(Relational & Tilecache) I could able to mentioned the folder(Key) names, so I tried to do with portal content directory to avoid multiple buckets.
