ArcGIS Enterprise 11.0\Pro 3.0.2: Why the “publish” buttons gets grayed out as the “feature” option is selected under the “copy all data” section?
651
10-06-2022 08:30 AM
JamalNUMAN
Legendary Contributor
As per the screenshot below, despite the fact that the relational ArcGIS Data Store is configured, the “publish” buttons gets grayed out as the “feature” option is selected under the “copy all data” section
What could be the issue here?
Jamal Numan
JonahLay
Hi @JamalNUMAN,
If you hover over the the Publish button, there should be a message that explains why it is disabled. Sharing a web feature layer that copies all data to ArcGIS Enterprise requires the privilege to publish hosted feature layers.
Please ensure that your member role allows you to publish hosted feature layers.
For more information, see the following topics:
Configure member roles
User types, roles, and privileges
Best,
Jonah
