Feature Class and connected Standalone Table in Portal
742
10-06-2022 06:24 AM
no33mis
Dear Community
I am struggling to find a solution for a simple issue in theory.
I have created a feature class and a standalone table using arcpy, and have enabled a 1-to-M connection between them. The main function of the standalone table is to add opening hours to the feature class points, e.g. one point has multiple opening times. However, I am not able to get this working in my WebApp Builder. I would like to add different opening times for each feature point, preferably within the smart editor. But there seems to be no connection between the FC and the table and I can only modify the fields of the FC itself.
Usually we publish each layer individually using a staging python script, but I have also tried to publish the web map as a whole (containing both) and the standalone table seperately as a table. I have also tried multiple widgets, without success.
In the end, I just want to be able to create point features and to add opening hours to them, which are stored in the seperate table.
Many thanks for any inputs.
