Hi all,
Like the title says, is it possible to import symbology packs to Portal map viewer?
For example, is it possible to have the the water utilities symbology (https://community.esri.com/t5/arcgis-online-questions/utilities-symbology-in-arcgis-online/m-p/32693...) in portal?
Thank you in advance.
Solved! Go to Solution.
Hi Andrede,
Is this what you are looking for?
https://support.esri.com/en/technical-article/000012539
-Calvin
Hi Andrede,
-Calvin
Seems like this is it! Thank you very much, Calvin. Cheers.
