Access Portal PostgreSQL
6916
6
09-17-2023 11:24 PM
MuhammadNaufalIhsan
Hi guys,
Does anyone know how to access the portal PostgreSQL? In datastore, I can use the listadminusers utility tools to get the username and password to access the database. However, I cannot find the same tools in the portal.
Regards,
Naufal
JakeSkinner
Esri Esteemed Contributor
@MuhammadNaufalIhsan ,
Note:  Exercise extreme caution when connecting to Portal's PostgreSQL database
1.  Open command prompt
2.  Change the directory to portal's PostgreSQL bin directory.  Ex:
c:\arcgisportal\pgsql_14.5\bin
3.  Connect using the initial Portal Administrator username/password when portal was installed:
If you do not know the username/password, this can be updated through Portal Administrator Directory > System > Database:
MiguelParedes
Greetings @MuhammadNaufalIhsan
Navigate to <drive>:\Program Files\ArcGIS\Portal\tools\createportal and use the command "listadministratorusertypes"
Usage: listadministratorusertypes -lf <arg>
<arg> is the path to the portal license file. The tool will list the user types compatible with the Administrator role that are in this license file.
Hope that helps.
Miguel
MuhammadNaufalIhsan
Hi Miguel,
Thanks for the answer! We haven't tried this solution yet since the other solution worked. But again, thanks for answering!
Regards,
Naufal
JakeSkinner
MuhammadNaufalIhsan
Hi Jake,
Thanks for the answer! We've tried this and it worked!
Regards,
Naufal
IqbalRidwan
Hi @JakeSkinner
Good day!
May I know if there is any downtime we can expect once we change the password and does it affect anything on the Portal/ArcGIS Enterprise itself? Etc: services restart/crash
I am looking forward to hearing from you.
Regards,
Iqbal
JakeSkinner
@IqbalRidwan yes, the Portal service will restart:
