A warning message appears to the user when opening the map
2968
11-05-2024 10:51 PM
FahadAlenezi
Hi
I desgin map that One of the users would not have access to a specific layer on a map
Every time this user opens the map, a warning message appears to him (I attached it)
I want this message not to appear to him? How can I do that?
ChristopherCounsell
MVP Frequent Contributor
Share the layer so that he has access or create an additional map without the layer.
Best practice is to ensure that all layers required for a map, and all layers/maps for an app, are accessible to the end user. Otherwise you will encounter messages like you are seeing that cannot be disabled, or the map/app may fail altogether.
FahadAlenezi
I do not want to share this layer with the user, but rather I want him to see other layers
While another user he can see this layer
in same One Map
Can I do that?
ChristopherCounsell
No, it is not how this is designed.
https://support.esri.com/en-us/knowledge-base/error-the-layer-layer-name-cannot-be-added-to-the-map-...
The simplest thing you can do is save the map as a copy and remove the layer. Two maps, one with, and one without the layers.
