Hello!
I just completed full migration from Enterprise 10.9.1 to 11.1. I have most everything back up and running except 1 custom SOE we have was using SqlConnection and System.Data.SqlClient to call a SQL command. I got a 'System.Data.SqlClient' is not supported on this platform. Thinking it was similar to the recent ArcPro add-in issue I swapped that out for 'Microsoft.Data.SqlClient' with the same results. This was working fine before the upgrade. Does any one have any input on this one?
Thanks!
Mike
With my SOE I don't get the '..is not supported' error until I acutally call the SOE extension from an app and I can see the error in the dev console. The SOE deploys fine and I can start the service with no problem. With the workaround, the SOE deploys fine but the service will not start due to the 'CLSID...' error.
Also, it is from a fresh 11.1 VS template and .Net Support is installed on Server.
Stumped...might need to wait for the update (hopefully a patch sooner than later).
I had that issue after attempting the workaround too. I suspected this was due to the way that I did the "unzip" and subsequent "zip" process. So I redid this exactly as Susan prescribed and it worked. That is, I renamed the soe file to be a zip file. Then I used File Explorer to navigate into the zip file and pasted the Microsoft.Data.SqlClient.dll from the bin\Debug\net6.0\runtimes\win\lib\net6.0 folder into the Install folder, which I had opened in my File Explorer. Then I navigated back out of the zip file and renamed it back to soe. When I updated my extension using THAT soe file, I was able to use my extension and it no longer errored out with the "is not supported on this platform" error. Now I am getting the "certificate chain" error that Susan mentioned. Oh esri.
I had the same issue, but needed to copy the Microsoft.Data.SqlClient.SNI.dll into the Install folder location within the .soe, too.
That file is already located in the .soe's runtimes folders:
After more reading, a simpler solution turned out to be updating the .csproj with the RuntimeIdentifier tag.
