Enterprise SDK 11 - Upgraded SOE now ruturns 'Microsoft.Data.SqlClient' not supported on this system.
2095
13
05-09-2023 12:10 PM
MichaelSnook
Hello!
I just completed full migration from Enterprise 10.9.1 to 11.1.  I have most everything back  up and running except 1 custom SOE we have was using SqlConnection and System.Data.SqlClient to call a SQL command.  I got a 'System.Data.SqlClient' is not supported on this platform.  Thinking it was similar to the recent ArcPro add-in issue I swapped that out for 'Microsoft.Data.SqlClient' with the same results.  This was working fine before the upgrade.  Does any one have any input on this one?
Thanks!
Mike
MichaelSnook
With my SOE I don't get the '..is not supported' error until I acutally call the SOE extension from an app and I can see the error in the dev console.  The SOE deploys fine and I can start the service with no problem.  With the workaround, the SOE deploys fine but the service will not start due to the 'CLSID...' error.
Also, it is from a fresh 11.1 VS template and .Net Support is installed on Server.
Stumped...might need to wait for the update (hopefully a patch sooner than later).
NWSCAD4
I had that issue after attempting the workaround too.  I suspected this was due to the way that I did the "unzip" and subsequent "zip" process.  So I redid this exactly as Susan prescribed and it worked.  That is, I renamed the soe file to be a zip file.  Then I used File Explorer to navigate into the zip file and pasted the Microsoft.Data.SqlClient.dll from the bin\Debug\net6.0\runtimes\win\lib\net6.0 folder into the Install folder, which I had opened in my File Explorer.  Then I navigated back out of the zip file and renamed it back to soe.  When I updated my extension using THAT soe file, I was able to use my extension and it no longer errored out with the "is not supported on this platform" error.  Now I am getting the "certificate chain" error that Susan mentioned.  Oh esri.
JohnMarquez
I had the same issue, but needed to copy the Microsoft.Data.SqlClient.SNI.dll into the Install folder location within the .soe, too.
That file is already located in the .soe's runtimes folders:
JohnMarquez
After more reading, a simpler solution turned out to be updating the .csproj with the RuntimeIdentifier tag.
