Export elevation profile without hover/highlighted point
1332
03-13-2023 09:44 AM
Status: Closed
wayfaringrob
Honored Contributor
Right now unless you hit the export button without mousing over the elevation profile, it exports with the highlighted/hover location.
This is usually not  desirable in a static format, so the option to export like this -- as it does if you go straight to the export button -- would be welcome. 
4 Comments
GeoffroyRicher-Lalonde
@wayfaringrob It might be fixed in a later version, but a quick fix for now could be to hit 2 times on the Flip direction button before exporting :
wayfaringrob
@GeoffroyRicher-Lalonde  thanks for the tip 🙂
jsphillips
Thank you @GeoffroyRicher-Lalonde for helping @wayfaringrob out!
jsphillips
Status changed to: Closed
Issue closed, as the workaround is reasonable.
