Unsolvable Images Removed log Error message
1600
08-25-2022 02:29 PM
IaGeoff
Anyone ever have subject error in processing Images with Drone2Map, being same error per post in ArcGIS Pro Raster options:
https://community.esri.com/t5/arcgis-pro-questions/ortho-mapping-block-adjustment-unsolvable-images/...
Getting on 2 seperate projects today, running RAW OBS. and Image Tags from DJI P4Pv2.  Camera Calibration comes back valid.  Yet Log file is returning Qty. of UNSOLVABLE IMAGES REMOVED message, then after "Estimating Initial Orientation and Camera Parameters..." message..... get the general ERROR 999999 with next line message of [GP][0][Error] Failed to execute (ComputeCameraModel) then "Geoprocessing Failed for Computing camera model".
Seems to be a notable result from ArcGIS Pro Raster options, yet Drone2Map (D2M) ??  using v2022.1.1 (patched).
Thanks, in advance.
IaGeoff
Just to add, attempted to Process the ESRI D2MGetStarted training data for Wrightsville Beach Project.  Changed some Processing "Tie Point" options (per https://www.esri.com/arcgis-blog/products/drone2map/imagery/troubleshooting-common-drone2map-issues/) setting Initial Image Scale to 1, and also "Matching Neighborhood" to Medium next, then tried Large on third attempt.
On Three attempts with this simple ESRI Project, default settings returned "Uncalibrated" Image results, as did the above changes.  Then changed Matching Neighbors to MEDIUM... got a bit farther in processing log, yet still creating the Unsolvable Images error and basically not even Adjusting Images / Dese Matching / etc., with Third attempt to LARGE still failing.
Attached Log file for the this ESRI Training Project, for reference.
Running v2022.1.1 on Win11 v21H2 OS build 22000.856
Lenovo ThinkSTA P620 w/Processor AMD Ryzen Threadripper PRO 5975WX 32-Cores 3.60 GHz
Installed RAM 64.0 GB (63.8 GB usable) using NVIDIA GeForce RTX 3080 Ti
Simply thought to share for additional reference.
Ricardo_Openware
I have the same error with drone2map "Compute camera model failed", any possible solution?
