Radiometric Quantity Type
1243
05-16-2024 04:22 AM
FranciscoCáceresClavero
I have a Micasense Rededge-P camera equipped with a Downwelling Light Sensor (DSL2) that measures the ambient light and sun angle for each of the five bands of the camera and records this information in the metadata of the TIFF images captured by the camera. I also have the calibration panel, and I take photographs on each flight mission.
1) What Radiometric Quantity Type should I use if I want to take into account the irradiance values provided by DSL2 recorded in the image metadata?
2) Is there a Radiometric Quantity Type that allows DSL2 data and calibration panel data to be used together?
CodyBenkelman
Francisco
for Radiometric Quantity Type you should use Reflectance.  See help here:
https://doc.arcgis.com/en/drone2map/latest/help/radiometric-calibration.htm
At this time we have not implemented support for the DLS inside Drone2Map.  What I would recommend is to capture images of the reflectance panel before and after your flight, and look at the DLS values for those calibration images and also for the images captured over your project site.  If the "before" and "after" calibration images have DLS values that are very similar (within a few %) and your flight images show consistent DLS values, your results should still be valid.
If the DLS data indicates significant changes during the flight (perhaps more than ~15%, but this is just an estimate) then you would need to consider how changes in your multispectral values from early vs. late in the flight may appear in your data.  e.g. if your flightlines run north/south and proceed from west to east, and illumination drops by 15% from first image to last, your spectral values MAY show a bias from west to east.
However, if you're using NDVI, this concern is largely reduced, since the normalization of the NDVI compensates for variable illumination.  Further, your drone will most likely change the exposure parameters to compensate for the change in illumination.
