portal license
2331
02-21-2018 07:51 AM
MCAGIS
We recently assigned our Drone2Map license to Portal. The login window lets me use the Portal interface to login, however once the program opens we get this popup (No license for user) and the program is closes out.
Any ideas on how to solve?
Thanks.
DerekLaw
Esri Esteemed Contributor
Hi MCA,
Did you explicitly assign the Drone2Map license to a specific Portal member?
Manage Drone2Map licenses—Drone2Map for ArcGIS Help | ArcGIS
Hope this helps,
MCAGIS
Yes that has been done. It seems to validate the Portal license through the popup login window, but as the program opens, it gives that popup saying 'user is not licensed to use Drone2Map' even though the Portal page says the user is licensed.
DerekLaw
Hi MCA,
Is the Portal member you've licensed level 2 and has a publisher role?
After you licensed Drone2Map did you restart the app to ensure that changes took effect?
Another suggestion to try and troubleshoot: verify that you've enabled the Drone2Map license to Portal correctly.
Hope this helps,
MCAGIS
Issue was we had a custom role, that Portal wasn't recognizing as a publisher. We have since fixed the issue. Thanks for everyone's help.
