Inspection Viewer Web?
3575
07-07-2016 01:15 AM
GünterDörffel
on some slides I saw something that looked like inspection viewer in a browser? How does that work? Is it planned/Available?
Thanks Guenter
MarkRomero
Hi Guenter,
There is a new widget for viewing oblique images now part of WebApp Builder. Web AppBuilder for ArcGIS | ArcGIS
I works by consuming an image service composed of oblique images.
GünterDörffel
Hi – yes – I am aware of the Oblique imagery widget. Tested it – works well. But what I am looking for is a way to use Drone2Map and its “Inspection Viewer” mode over the web.
Drone2Map can upload Services for 2D and 3D results to be consumed in WebMaps and Scenes. It is only the “inspection viewer mode” that can only be used with the desktop version of Drone2Map. No “Web-way” for this, yet.
In theory adding the images to an Image Service and publish it to your own server would work “similar” – but when using Inspection mode in Drone2Map the required image information for adding it to an ImageService is not generated by Drone2Map … That’s where the problem starts …
Is there a plan to have a WebViewer or widget for that?
Regards
Guenter
Von: Mark Romero
Gesendet: Mittwoch, 13. Juli 2016 14:15
An: Dörffel Günter <[email protected]>
Betreff: Re: - Inspection Viewer Web?
GeoNet <https://community.esri.com/?et=watches.email.thread>
reply from Mark Romero<https://community.esri.com/people/mromero-esristaff?et=watches.email.thread> in Drone2Map for ArcGIS - View the full discussion<https://community.esri.com/message/620640?et=watches.email.thread#comment-620640>
