Drone2Map Thermal Orthomosaic using a DJI Matrice 300 RTK and Zenmuse H20T camera
3747
10
08-23-2023 12:59 PM
Sanforan
Hi there,
My organization is interested in expanding our drone service offerings by purchasing a H20T camera to allow us to capture and produce thermal imagery. I was just wondering if Drone2Map is capable of creating an orthomosaic using thermal images from a Zenmuse H20T camera?
According to some Drone2Map manuals and guides I've found, R-JPG processing is currently supported, however, the H20T isn't on the compatible camera list for Drone2Map. Apparently, the H20T uses some form of proprietary (DJI's) R-JPG file format that is somehow different from FLIR's, so I wasn't sure if Drone2Map would work in our case, or if I should be looking at learning some different post-processing software, such as Pix4D?
Any help on this would be greatly appreciated 🙂
RockRunEnterprises
Definitely in C, converted to F with Raster Functions "Unit Conversion" in Pro.
Awesome results. Thanks for the effort @CodyBenkelman
