Drone2Map not recognizing license
1936
02-02-2024 11:10 AM
CarlosRodriguez_LA
I have a D2M license via my AGOL account just like my Pro license (as shown in the screengrab), but when I launch the D2M I'm unable to launch due to the prompt saying "not licensed" (see screengrab). My organization hasn't used D2M in over a year, now we have a project that we need to process and I just can't figure out how to solve this. I'm hoping someone has experienced something similarly and solved it! Thank you in advance.
Tags (3)
MarkBarker1
Hi @CarlosRodriguez_LA ,
I take it you are on the latest version of Drone2Map? (2023.2.1)
Please also check that you are on one of the foundational user types required, Creator or Professional.
Lastly, I would make sure that your license is still current and hasn't expired since you said you haven't used it in quite awhile. Its possible that you are still able to assign it in AGOL with it being expired.
If all of that seems correct, then I would reach out to technical support where they can troubleshoot further.
Regards,
Mark
MarkBarker1
Regards,
Mark
CarlosRodriguez_LA
Thank you for the info. We ended up uninstalling the old version and installing a newer D2M file. That seemed to fix the problem for us.
