Drone2Map hanging when processing larger projects
2334
05-04-2022 01:28 PM
CoadyCameron
I've found that Drone2Map will hang in processing on larger projects. The program itself does not freeze as you can still click buttons, and no error messages are thrown. The progress bar will reach a certain point in processing and then not continue from that point, note the progress bar animation still runs.
The screenshots attached show a batch job where it is stuck on "Adding mosaic dataset rasters started 71%" for several hours. I've noticed this will happen whether I am doing a single project or batch project.
The hardware on the workstation is well beyond D2M requirements, so I don't believe that is the cause. I am using the default settings on the 2D Full option.
Has anyone else experienced this issue?
System Info:
  • D2M Version: 2.3.3
  • Processor: Ryzen 9 5940x 16-core
  • GPU: RTX 3070 Ti
  • RAM: 64GB
  • Storage: 2TB M.2 SSD (1.53TB free space)
  • Windows 10 Pro
CoadyCameron
Turns out the progress bar and event logger locks up, the program is still working.
In my case Drone2Map hung at 71% and "Adding mosaic dataset rasters" for about 4 hours, but then all of a sudden the project finished.
