Drone2Map - executed with an 'Cannot Authenticate Application' error
4838
07-05-2017 05:58 PM
Dong-gyunKim
I would like to appreciate it if you inform me any information or solution regarding this error.
I've installed Drone2Map for ArcGIS 1.2 succssfully.
And when I execute the Application, returned the below message.
X  Cannot Authenticate Application
Also, I tested below that.
1. Repair
2. Remove(including registry file) and reinstall
------------System Environment-------------
OS : Windows 10 Pro (64bit)
Processor : Intel(R) Core(TM) i7-3720QM CPU @ 2.60GHz
RAM : 16.0 GB
System Locale : Korea
Thank you
Dong-gyun
JamesTaylor3
Esri Alum
Did you install Drone2Map for ArcGIS behind a firewall (with no access to www.arcgis.com) and intent to license to a Portal for ArcGIS?
If so this is a known issue with Drone2Map 1.2.   The first time you start Drone2Map it attempts to license to www.arcgis.com.  If you are behind a firewall then licensing can not reach that url and the application will not open.  (apologies, this has been corrected and will be released in a future build).
The work around is:
Edit the file "C:\Users\<user>\AppData\Local\IsolatedStorage\zovy5ns2.wpc\polmcoza.1d1\Publisher.kakyaydnplrkukgdwqg2aisd4iopallh\AssemFiles\LicensingOptions"  (the specific path may be different on your system).
It will contain:
https://www.arcgis.com
True
You need to edit this file to contain your on premise URL:
https://myserver.mydomain.com/portal
False
Dong-gyunKim
Thank you for your advices.
I shout down the firewall.
And edited the 'LicensingOptions' file to
False
However, the App still return the error message.
Please let me know any others.
JamesTaylor3
Esri Alum
Are you licensing against an ArcGIS Online Organization or your own on-premise Portal for ArcGIS?
Dong-gyunKim
I want to use AGOL and Portal for ArcGIS.
so, I've tested below four types.
True
https://esrikrbdd.maps.arcgis.com
True
False
http://portal.esrikr.com/portal
False
HenryLindemann
The solution that worked for me was the following.
1. Uninstall Drone2map
   This does not remove all the settings though.
2. Remove/Backup the settings folder
   C:\Users\<your_user>\AppData\Local\IsolatedStorage\qevc5fgp.m0l
   qevc5fgp.m0l : this is a randomly generated folder name
NB! Please note editing the registry can compromise the stability of your operating system, please make a backup of the registery before hand.
3. Remove this registery entry Computer\HKEY_CURRENT_USER\Software\ESRI\Drone2Map
4. Reinstall Drone2map.
These steps will bring back the initial configuration screen.
Also make sure to upgrade ArcGIS Pro before following these steps.
