I am new to Drone2map so I apologize if my question is too basic/badly explained or if it has been already answered (even if I haven't find any similar problems on the internet).
I am having trouble while processing, since the following error appears when i start the process:
[Product] Product generation failed. Could not add output of type OMWorkspaceMosaicDatase/MosaicDataset (source: C:\Users\doubl\Documents\Drone2map\Projects\2023_07_04\2023_07_04.gdb\Image_Collection)
[Processing] Create mosaic dataset failed
[Processing] Fatal Processing Error
[Misc] Processing Failed
[Processing] Could not create mosaic dataset
I am using the default process options, you can find the template attached.
Does anyone have suggestions about what could be the problem?
Thank you in advance!!
