Authentication Portal cannot be reached (firewall issue)
5546
8
08-02-2016 01:08 AM
GeorgieCassar
At work I get this error when opening Drone2map.
I can open drone2map successfully from my home laptop where I am using wifi.
Is there a domain I can add to our firewall white list to enable this authentication portal to be reached ?
KristaHeinrich2
Thanks Tony,
That did it, it was a combo of the *arcgis.com and the *esri.com that needed to be whitelisted.
Cheers,
Krista
RakeshModi
I am having same problem after successful installation --
GeorgieCassar
Rakesh
I resolved the issue by uninstalling Drone2Map, downloading the latest version of the software and reinstalling.  They have fixed this problem with the last release it appears.
GeorgieCassar
I take that back.  It's not working again so will attempt to white list the URLs.
KristaHeinrich2
This does not appear to have been fixed in the trial version. I downloaded version 1.0.1 today and am still receiving that same error.. any word on when this will be fixed?
AnthonyMason
Krista,
Could you try to whitelist the following ArcGIS domains:
•http://*.arcgis.com <http://%2A.arcgis.com/>
•https://*.arcgis.com <https://%2A.arcgis.com/>
•http://*.arcgisonline.com <http://%2A.arcgisonline.com/>
•https://*.arcgisonline.com <https://%2A.arcgisonline.com/>
•http://*.esri.com <http://%2A.esri.com/>
•https://*.esri.com <https://%2A.esri.com/>
Thanks
Tony
KristaHeinrich2
Thanks Tony,
Cheers,
Krista
MohamedHamoud
I have the same problem, but I couldn't find the right way to whitelist a domain. Can you please explain the steps of whitelisting the required domains?
KristaHeinrich2
Hi Mohamed, I had to speak to my IT department as they were blocking the domains through their security set up. Unfortunately it wasn't something i resolved myself  so i don't have details.
