ArcGIS Data Interoperability for Desktop 10.4 error 1714
3749
10-24-2016 01:47 AM
JaapDijkstra
Goedemorgen,
Graag wil ik de data interbility extentie instaleren maar op een of andere manier lukt dit niet.
Zie voor omschrijving van het probleem de bijlagen..
Graag info hoe en waar ik dit kan oplossen...
JayantaPoddar
Do you see a setup.exe file in the extracted folder? If yes, try to run it as an administrator from Windows Explorer. If the issue still persists, I would suggest you to raise a ticket with your Esri Tech Support/ Disributor.
Think Location
JaapDijkstra
Hello,  Yes a did try your suggestion but stil not working.
Also try to uninstall all ArcGis programs,
Cleanup registery from all entrys that have "ArcGIS'or 'Esri' on it.
Cleanup local drive's C and D
Install all again but afterall the same error.
Installing on another pc with no problems.
The only differents is i use Windows 10 (on drive C) with redirection of all my document and lots of programs to drive 'D'
And also i see i could not change the install directory of Data Interopperbility setup........???? (could that be the problem ??).
So i think its a bug or something in the register of my pc thats give this error.
Thanks for your comments...
