Add license 10.2 on License Manager 10.0
4287
01-27-2015 08:46 AM
MAPAQ_organisation_
Is it possible to install a license 10.2 on License Manager 10.0?
RebeccaStrauch__GISP
Hakim, if you are asking whether an ArcGIS Desktop 10.2 can access a license from a10.0 license manager, the answer is no.
however, a 10.0 Desktop is compatible with a 10.2 license manager, so if you have a mix of versions being used by users, you should upgrade to 10.2 or 10.3 (the proper license file from esri is required) and then all could access.
MAPAQ_organisation_
Thank you for your quick answer!
Hakim Benabdallah
418-380-2113 #3919
De : Rebecca Strauch
Envoyé : 27 janvier 2015 12:18
À : Benabdallah Hakim (DRI) (Québec)
Objet : Re: - Add license 10.2 on License Manager 10.0
reply from Rebecca Strauch<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo7A4BXwO9PY1WvQ5cXCtK4-2BystPtvc2MEqMDG3BOcPSbdlUmkmuekoBmZpFWu8NknHC2IgsEBq09s82izTxavKo-3D_B53CMv4pr9nyGTokne8IdieXOySYF6TsDS5B-2Bwknu2nIUT7aDq4O6x490lQlMceMg36wGlLJPw8DfsFMrExiPdlVU-2BAaybkXeOD-2FwLC0ldYSnPS6OXS-2Ft6uJuUz4EujCWUkOb21MCllOhb1TZ-2B0Fy8RH5rpocJquzU9wQSJF1dpROJDWOwPO7FjodXSkd2JimegMap8HsF1PB5tIJbe7si0y7mA2ZSPH-2BqfxI00HQxJEFbhABVMAunCbAsu3i1xAke2HaiN1U4d1YezXeCDTECvvHA2mmb10fsKhNSXpmDKl4bP5u0r-2BnAWro4v7hAMSQWTGDoxSXMrybyCOKce-2Fcw-3D-3D> in ArcGIS for Desktop Installation support - View the full discussion<http://jiveon.jivesoftware.com/wf/click?upn=Dg1s4x8le7Lmxv8KWGaqo0VQjeJBYpG9HGC8QZBT-2FEzyKsgp8ALamsPl7Pz3jQz1j4ks4j7BcWx9cGjYYv9XM6MoZQ9D91cTJdpaDAnNuMM-3D_B53CMv4pr9nyGTokne8IdieXOySYF6TsDS5B-2Bwknu2nIUT7aDq4O6x490lQlMceMg36wGlLJPw8DfsFMrExiPdlVU-2BAaybkXeOD-2FwLC0ldYSnPS6OXS-2Ft6uJuUz4EujCWUkOb21MCllOhb1TZ-2B0Fy9xu9Pqwssxe61o1vds1M6BObLWyKRu5ltNwFr06s3btSiF-2F7dISsW7CoovTVhO0h5YSDC-2F4rP7plhEJEygrOBoprnN6uawip3mUu-2FIxiA-2BVWhmSGQ3RR1ERx9wR7cS4mNXvFOOI6GiagONQbdO9Ul9nOj0qX2RY8VIxy-2BeR7I36fXn4gLMw-2FxR4EbxPDGNM1g-3D-3D>
Reminder: If it did answer you question, make sure to mark it as correct.  If not, make sure to rephrase your questions.  Thanks.
AndySmith
Hi Hakim,
Rebecca is correct.
You cannot place a 10.2 Concurrent Use license onto a 10.0 License Manager. The License Manager must be the same version (or higher) as the license type you wish to authorize.
Also, the License Manager must the same version (or higher) as the clinet machine trying to connect to it, i.e. a 10.2 client cannot connect to a 10.0 License Manager, but a 10.0 client can connect to a 10.2 License Manager.
My recommendation would be to always run the latest version of the License Manager, and ensure that the license are upgraded to match it. This way, all client machines will be able to connect to it, regardless of what version they are on.
