SQL Executor syntax for update statement using @Value for a string
3002
06-03-2024 01:58 PM
MichaelKohler
We have a FME workspace where I need to update rows in the table that meet a where condition. The condition is a string value. When I set up the sql statement it is like this.
UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where 'PARCELID' = @Value(PARCEL_NUMBER)
and when the executor is run, the below error is returned for each feature.
Query failed, possibly due to a malformed statement. Query Text   UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where 'PARCELID' = 342073103690008  Provider error `(-2147217913) Error converting data type varchar to numeric.'
The PARCEL_NUMBER and the PARCELID fields are TEXT in both instances. This is what was used in python.
UPDATE ADDRESSES_TEST SET internalonly = 1 WHERE PARCELID = '{}'
 where the PARCEL_NUMBER is quoted. Also, internalonly is a smallint in both databases
Any leads would be greatly appreciated.
MarceloMarques
use SQL Server function CAST or CONVERT
https://learn.microsoft.com/en-us/sql/t-sql/functions/cast-and-convert-transact-sql?view=sql-server-...
| Marcelo Marques | Esri Principal Product Engineer | Cloud & Database Administrator | OCP - Oracle Database Certified Professional | "About: In 1992, I embarked on my journey with Esri Technology, and since 1997, I have been working with ArcSDE Geodatabases, right from its initial release. Over the past 33 years, my passion for Spatial Databases and GIS data has become a central part of my career.." | “ The mountains are calling and I must go.” – John Muir |
BruceHarold
Esri Frequent Contributor
Michael the single quotes around PARCELID make it a literal and not an identifier.  Just remove them.
MichaelKohler
Thanks for the quick reply.
Both statements with, and without the single quote return the same error.
Microsoft SQL Server Non-Spatial Reader: Query failed, possibly due to a malformed statement. Query Text `UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where 'PARCELID' = 340750300650005'. Provider error `(-2147217913) Error converting data type varchar to numeric.'
and
UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where PARCELID = @Value(PARCEL_NUMBER)
Microsoft SQL Server Non-Spatial Reader: Query failed, possibly due to a malformed statement. Query Text `UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where PARCELID = 342073108650005'. Provider error `(-2147217913) Error converting data type nvarchar to numeric.'
The parcel number is a text string and should have quotes. This works with python and in SQL.
update ADDRESSES_TEST set internalonly = 1 where PARCELID = '342073103690008'
if i take the quotes away from the PARCELID and run in SQL, the same conversion error is given
Very much appreciate your help.
MarceloMarques
MichaelKohler
Thank you. That did the trick
UPDATE ADDRESSES.dbo.ADDRESSES_TEST set internalonly = 1 where PARCELID = CAST(@Value(PARCEL_NUMBER) As nvarchar)
MarceloMarques
Glad to help.
