Hi !
I have a point hosted feature layer called "Fitting_Collection" which is being used in data collection using field maps. I have created a dashboard to track the progress of the field operations.
Now i am trying to create a list of the category of the fittings and the count of them using Arcade groupBy functions in the list element of dashboard (Data Expression).
Since the category column ("Fitting_Type_DMZ") is subtype field i am getting the subtype code in the table. I tried to use the Decode function but i did not able to use properly due to my little knowledge on Arcade data expr4ession behavior in Dashboard. Please see the code below. I also tried to use dictionary but i could not add properly i believe.
I came to see many helpful posts by @jcarlson but i could not able to implement !
Also I want to get rid of the null records. I would love to hear any comments /solutions on this. Thanks in Advanced! 😊
// STEP : 1
var p = Portal("https://arcgis.com");
var fs = FeatureSetByPortalItem(
p,
"4ee2810f5ff947338c9e10b660462c1f",
0,
["Fitting_Type_DMZ", "CreationDate", "Surveyed_By"],
false
// return fs;
// returns a meaningful value when a field contains coded values
var code = fs.Fitting_Type_DMZ;
var decodedValue = Decode(
code,
2,"Air Valve",
4, "Gate Valve",
6, "Flowmeter",
9, "Zone Valve",
12, "Boundary Valve",
"Unknown");
return GroupBy(fs, ["Fitting_Type_DMZ"],
[{name:"Counts",
expression:"Fitting_Type_DMZ", statistic:"COUNT"}]
You can do this with a SQL expression in your GroupBy function. This expression effectively recreates your Decode function, but in the GroupBy process itself.
var filt_fs = Filter(fs, 'Fitting_Type_DMZ is not null')
var type_sql = `CASE
WHEN Fitting_Type_DMZ = 2 THEN 'Air Valve'
WHEN Fitting_Type_DMZ = 4 THEN 'Gate Valve'
WHEN Fitting_Type_DMZ = 6 THEN 'Flowmeter'
WHEN Fitting_Type_DMZ = 9 THEN 'Zone Valve'
WHEN Fitting_Type_DMZ = 12 THEN 'Boundary Valve'
ELSE 'Unknown'
END`
return GroupBy(
fs,
{ name: 'Fitting_Type_DMZ', expression: type_sql },
[{ name: 'Counts', expression: 'Fitting_Type_DMZ', statistic: 'COUNT' }]
Note that calling the Decode function does not alter the original FeatureSet, it can only be used to create new variables or values.
I understand we can achieve this by using Table element. but I dont want to. because in the same list i will need to groupBy the Date (Without Time) and a filter "Today" so i can see the counts of survey for each type of fittings in the list.
ELSE 'Unknown'
END`
return GroupBy(
fs,
Hi Josh,
This worked just fine for me. huge thanks !😊
