Toggle the Serial and Pie chart in Dashboard
2391
12-22-2023 02:12 AM
AnujKumar5
How can we add Toggle button for two chart (Pie and Serial or Bar ) in Dashboard. the chart will appear in same tab.
Attached Image for the reference
help apricated.  Thanks.
rwrenner_esri
Esri Alum
It sounds like you're proposing a new type of widget interaction in dashboards. Given that this functionality doesn't yet exist, this would be a great candidate for the the idea board.
rwrenner_esri
Esri Alum
In Dashboards, Pie Chart and Serial Chart are separate widgets. Once both widgets have been configured, you can stack them to show them on tabs that can be "toggled" and/or group them to show them next to each other (on the same tab if applicable).
More info on managing widgets is here.
-Rylee
AnujKumar5
Hi Rylee,
Understand we have options Stack and groups , but need actual toggled button. where can be toggled with Serial(Column and Line)Chart. in same groups/tab
rwrenner_esri
Esri Alum
